Re: McCormick W4 hard starting
Posted by A.J. Lambert on October 24, 2010 at 16:56:23 from (209.156.114.98):
In Reply to: Re: McCormick W4 hard starting posted by Tom Fleming on October 24, 2010 at 16:39:27:
Once it fires up it runs fine. Throttles right up to
full speed with no hesitation. Has no problem
keeping full RPM and governor works as it should. If
you have any more questions write back and i will
try to explain them as best as i can. Thank you for
the quick reply
