Re: Farmall B cultivator rear sweeps
Posted by gene bender on October 24, 2010 at 19:31:52 from (67.55.227.196):
In Reply to: Farmall B cultivator rear sweeps posted by Jerry Hancock on October 24, 2010 at 15:15:05:
There should be two braces one on each end to hold the bar you describe the drivers side has a long and short one lest side will have one long one that matches the right side and then a flat bar goes to the top of the diff housing. There should be two shorter ones bolting to the top of the tranny behind the gear shifter. You need a manual to make sure you have all the parts. The model of the cult could be several as they made at least three models. Is it hand lift or exhaust as the levers are different and if its hand lift you need a lever that bolts to the drivers platform. I have some parts if you are short.
