Without float and with the lock pins installed in the hitch it will stay at whatever height you move it to. With float you can move the valve to a position past down and the hitch will float up and down. Like if using a scraper blade it would move up and down by its weight and ground conditions. If you pull the pins in that type hitch you can have float without a float position valve. I have used the prince open center valves with float and its pretty handy. Use the one with load checks to keep the hitch from leaking off unless its leaking in the lift cylinder or hoses after valve.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
