Re: Best way to take the wander out of a front end..
Posted by john d on October 25, 2010 at 19:15:47 from (69.11.149.9):
In Reply to: Best way to take the wander out of a front end.. posted by OliverGuy on October 25, 2010 at 16:33:23:
In my experience, the little ball bearing on the front end of the steering shaft is often a culprit. It's easy to change, and not expensive.
Take the hood off, and see if the universal joint in the steering shaft is worn. That's another easy fix.
Front wheel bearings can cause wobble, as well as worn bushings in the front bolster.
