Posted by IHCPloughman on October 25, 2010 at 19:54:39 from (173.29.64.50):
In Reply to: little genius plowing posted by farmallboy15 on October 25, 2010 at 18:28:53:
If you have the mounts you just need to go to your friendly CIH dealer and ask for plastic trashboards, they are the same for HSKA, Plow Chief, and Super Chief; just the mounting bracket is different. They were nine or thirteen bucks a piece a few years ago.
Was your trash getting caught on the beam above the bottoms? Trashboards aren't going to help, the trash will just get caught in the trashboards. You need to sharpen you coulters with an angle grinder and then adjust them properly so they are adequately cutting the surface trash. Your coulter jointers probably aren't helping the situation either, you should take them off until the coulters are adjusted and you are confident with your plow settings. Coulter jointers work well only when everything else is set properly, otherwise they are a huge pain.
You got one heck of nice plow that is well equipped: coulter jointers, trashboards, Plow Chief bottoms, and the correct moldboard extensions. The jointer blades look like Ford, and I assume the coulters are also, but what the heck, the Ford jointers will probably work better than IH jointers. Also, you should slide the plow hitch forward and use the last hole they give to make the hitch as long as possible. The longer the hitch, the less the hitch angle changes as you change depth or travel over rolling ground. Good luck on your plow adjustments.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
