Schwartz Wide Front End
Posted by Matt Weltz on October 25, 2010 at 23:58:31 from (216.81.154.233):
Will a Schwartz HD wide front off a 400 fit a 560 or are the mounts different? If they are different, can someone explain the difference of them? Thank you!!!
