Re: Best way to take the wander out of a front end..
Posted by mkirsch on October 26, 2010 at 05:10:07 from (64.80.108.57):
In Reply to: Best way to take the wander out of a front end.. posted by OliverGuy on October 25, 2010 at 16:33:23:
You're going to find that it's a combination of multiple factors.
1. Wear in the worm gear.
2. Wear in the top and bottom bushings.
3. Wear in the U-joint.
The gears are extremely costly, but the bushings are affordable. Usually you can turn the gear 180 degrees on a Super H and find a new sector.
Heck, you may take the top off the gear case cover and find that the nut has come loose. It may be that simple.
I had to do the beer can shim trick with the sector gear on my Super H. The vertical shaft was also worn some.
