Re: Re: Hyd. oil into crankcase
Posted by miduss on June 22, 2000 at 20:44:46 from (209.115.125.245):
In Reply to: Re: Hyd. oil into crankcase posted by Les Repair on June 22, 2000 at 18:21:05:
I just got done fixing the same problem on my Super A. I beleive that the C and the Super A have the same hyd. pump.
There are 2 cover seal rings ( 0 rings ) under the cover bearing spring under the cover bearings. There is an oval O ring which serves as the body seal ring. There are also two O rings that are at the hose connection. It sounds like these are the O rings that you replaced.
Where the drive gear shaft exits the pump body is a seal. This is where my leak was, consistant with what you have already been told. IH used pumps with two different types of drive shaft seals. One type used a pressed in seal. Mine on the other hand had an O ring in pump cover. The O ring seals around the drive shaft and is located in a slot cut in the hole of cover. I did not see it the first 3 times I looked for the seal.
My local IH dealer had a complete kit with instruction for under $20.00. It did not take very long to fix and it works fine.
Hope this helps.
Post A Followup
: Re: Re: Re: Hyd. oil into crankcase
