Re: engine/transmission bumping?
Posted by CharlieNJ on October 26, 2010 at 16:39:36 from (174.57.220.136):
In Reply to: engine/transmission bumping? posted by e-manhunt on October 26, 2010 at 08:03:58:
Check into your radius arms on the front end. These arms control the radius of the arc the wheel travels over a bump. The front of the radius arm is like a "Y" that attaches at the axel. The back of the radius rod is a large bolt which passes through a bracket rivited to the frame. On the bolt, on both sides of the bracket are some heavy rubber or nylon "doughnuts" and washers, held tight with a big nut. I believe your doughnuts are worn or missing.
CNJ
