Posted by Janicholson on October 26, 2010 at 18:07:01 from (67.72.98.57):
In Reply to: IH 444 clutch posted by Anderfam on October 26, 2010 at 17:24:29:
With respect, the clutch is engaged, it won"t disengage. This common problem with stick shift vehicles, is due to the clutch friction disk being stuck to the flywheel. Three things will stick it, one is humidity that rusts it to the iron of the flywheel. the second is mouse poop/pee that can corrode the two together. The third is varnished up old oil contamination from a leaky main bearing, over greasing the pilot bearing, or a trans oil leak.
Move the tractor in neutral so that it heads toward clear territory (no trees cars or buildings for a long way, options to drive for 1/4 mile is good even it it is around and around where tire tracks will be OK). Block the clutch pedal down with a piece of wood and tape the wood in place. With it not running, but warmed up so it starts easily, put the tractor in 3rd gear, and start it. It will probably start moving forward. As it does, give it about 1/2 throttle, then hit the brakes to shock the clutch/flywheel junction. This applies force to the stuck parts and will probably free the clutch. Repeated braking to almost stall will help, if it does not come loose at first. In some rare cases it is necessary to split the tractor to free the clutch, but I would say less than one in 30 need that effort. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
