Re: Brush Guard for M ?
Posted by Wardner on October 27, 2010 at 10:58:20 from (4.154.238.245):
In Reply to: Brush Guard for M ? posted by Melvin Ware on October 27, 2010 at 07:07:30:
third party image
This grill guard won't get ripped off. I believe that IH made it. It came off an I-9. I put it on this tractor for front ballast. It is made from 1/2" plate. It's similar to a TD-9 grill guard. Perhaps you could find something in a construction salvage yard.
My brush hog tractor is a SMTA. I made a V shaped frame out of heavy wall 3x3" square tubing. The apex is about one foot in front of the bolster. Both sides sweep back to the outside of the rear tires. It will clear 3-4" trees. Anything bigger will push the tractor sideways. Those are too big for the hog anyway.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
