Posted by pete 23 on October 27, 2010 at 21:23:36 from (184.12.32.90):
In Reply to: 300 TA Adjustment posted by Bouncer on October 27, 2010 at 20:42:06:
TA adjustment won't bother you while not running as far as shifting into or out of gear. Worn out or messed up shift lever and rails could or bearing out of transmisson top shaft. TA adjustment amounts to , free play on direct drive clutch of about 1/8th to 3/16th inch movement of TA release shaft and then adjust link between clutch and TA so it moves immediately when pushing clutch pedal and releases ta same amount as pulling ta lever. What you are trying to acomplish is full release of the 7 inch dry direct drive clutch so planet gears can revolve freely and allow rollback of transmission gears to relieve tension of load.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
