Re: Mess'n with the governor on '41 H
Posted by CJ_1080 on October 28, 2010 at 05:49:23 from (166.225.67.117):
In Reply to: Mess'n with the governor on '41 H posted by Yooper Farmall on October 27, 2010 at 13:45:02:
This is a modification fairly common in tractor pulling, will work here too! What ya want to do is pull the fly weights out, get a cutting wheel out, and lighten them up. There is usually a casting flash half way down the weights, trim them down to just above that. If not trim an 1/8 inch at a time and check the outcome. Make sure there isn't any slop in the pins on the weights, and the linkage. A stiffer spring as previously mentioned may help, but if this is a work tractor and not a play tractor, it may take some time to get used to the throttle response. That with some careful adjusting will get you any rpm you want! Good luck. It isn't as hard as it sounds!
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
