Re: farmall h governor
Posted by Yooper Farmall on October 28, 2010 at 08:50:26 from (141.210.112.16):
In Reply to: Re: farmall h governor posted by Solid Laber on October 26, 2010 at 18:16:03:
Sorry if this is a simple question, I haven"t had experience with govenors before. I"m gathering that one can shave down the fly weights or put in a stiffer counter spring and either will increase rpms while not adjusting the lowest idle speed. Replacing the spring with something stiffer will make the throttle respond differently but shaving down the fly weights doesn"t? How does the throttle respond differntly with a stronger spring? Thank you in advance, this board is a wealth of information, extremely valuable!
