Posted by rustyfarmall on October 28, 2010 at 07:58:35 from (209.152.78.140):
In Reply to: Brush Guard for M ? posted by Melvin Ware on October 28, 2010 at 07:35:33:
The grill insert has a "wing" on the backside. You loosen a screw, position the wing so the insert can be put in place, then put that wing into a vertical position and tighten up the screw from the front. Many of these were lost because either the screw was not made tight enough, or it just palin loosened on its' own accord and the insert just fell out where it was then ran over by the tractor and destroyed.
If being correct is not an issue, just find a piece of window screen and wire it on over that opening.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
