Posted by mkirsch on October 28, 2010 at 08:16:25 from (64.80.108.55):
Hey, can you verify these mechanical TA modes of failure?
1. Does not move with TA lever back = ramp and rollers are shot
FIX: Install rebuilt TA unit or rebuild existing unit, requires double split
2. Moves with TA lever ahead or back, but does not change speed, shifts easily, freewheels down hills = TA clutch is shot
FIX: Replace TA clutch, and throwout bearing if necessary, requires single split at bell housing.
3. Moves with TA lever ahead or back, but does not change speed, difficult to shift, does NOT freewheel down hills = TA clutch badly out of adjustment, or TA throwout bearing shot
FIX: Try adjusting TA clutch to spec. If that doesn't work replace TA throwout bearing.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
