Re: M Spark ?
Posted by old on October 28, 2010 at 14:29:52 from (4.245.15.0):
In Reply to: M Spark ? posted by MIKEINLC on October 28, 2010 at 13:58:33:
If your points are bad that could be your problem or you wired it wrong etc. I would pull the distributor cap and open and close the points by hand. You should both hear and see a spark at the points. If you do not then the points are bad or you have a short in the system between the coil and the points
