Posted by El Toro on October 28, 2010 at 15:43:56 from (108.3.200.96):
In Reply to: car problems posted by best785 on October 28, 2010 at 14:27:12:
Hold your hand over the throat of the carburetor and see if you have good suction while a helper makes an attempt to start the engine. If you have very little suction means your intake manifold vacuum is low. Check your intake manifold to make sure it is tight. Do a compression check and see and compare your readings. Valves could be leaking, rings stuck in the ring lans (grooves) and worn sleeves. You need good intake manifold vacuum to draw that atomized fuel into the combustion chamber. Hal
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
