Posted by charles p on October 29, 2010 at 09:54:31 from (199.120.189.2):
In Reply to: f12 serial number ha5 posted by charles p on October 25, 2010 at 17:38:25:
thanks a lot "36F30." i took your information about the high altitude and removed the spark plugs and rolled engine over to check. all 4 cylinders have the stepped pistons. 3/4 of piston head on left side has got a flat raised step of about 0.25" inch high and the last 1/4 of piston head on the right side is lower. definitely matches the "HA5" as high altitude with having the higher compression pistons to match. the f12 doesn't run yet as needs an ignition tune-up, but do i have to do anything with the timing on the F4 magneto cause of the high compression pistons? keep the timing adjustment lever on the retard side? by the way i learned quite a bit and many thanks for your help.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
