Re: CaseIH595XL hydraulics problem.
Posted by fishiey on October 30, 2010 at 01:03:00 from (118.82.158.155):
In Reply to: Re: CaseIH595XL hydraulics problem. posted by karl f on October 29, 2010 at 10:36:53:
Hi have tried all draft positions with no sucess.Have since found last owner had trouble with linkage not droping at all (loaded or unloaded),He would clean out Unloading valve from the bank under the seat, linkage would then work for another two hundred hours and then need recleaning. We have tried this, and even swapped the whole bank with one from our 695 but it made no difference. problem could be internal in the action valve, any ideas on how to deal with this.
Thanks
Ron
