Re: Farmall MD Wiring Help
Posted by Janicholson on October 30, 2010 at 07:15:35 from (67.72.98.45):
In Reply to: Re: Farmall MD Wiring Help posted by Matt Weltz on October 29, 2010 at 18:24:17:
third party image
The diagram above will do the trick.
There are two gray wires going to switches (bottom right of illustration) these are for the three wire normal 10SI Delco or Hitachi. If you ignore these exciter wires because your one wire does not need them, you will see that the remaining fat black wires from the Alt to the gauge, and from gauge to starter switch, Plus the one gray wire to the lights, are all you need. I recommend a fuse link be placed in the wire where it attaches to the starter switch.
(starter switches can be as shown, or a square push button, or a rod activated push button, or changed by an owner to almost anything. If you find the big positive wire from the battery, it will be attached on its other end to the starter switch no matter what it looks like. This is where you should attach the wire to the fuse link. This prevents a failed alternator from starting a fire. The fuse link (NAPA has them) should be about 10% higher rated than the alternator output.
There is no connection to anything on your mag at all. Voltage is never supplied to it for any reason. It is grounded to stop the tractor.
If the wiring harness you have purchased has smaller wires running from the electrical box to the alternator, ignore them, or tape them up.
Jim
