Re: 350 utility tractor Overheating
Posted by Janicholson on October 30, 2010 at 07:29:22 from (67.72.98.45):
In Reply to: Re: 350 utility tractor Overheating posted by richard Geist on October 30, 2010 at 03:42:58:
MKirsch is correct.
That belt should not be tighter than about a one inch hard push with your thumb between the pulleys.
it is not to be "tight". If tight it will ruin the fan hub bearings.
There are many posts in the archives on adjusting that pulley. Do not get aggressive with it, and remove the setscrew and lube it with penetrating oil before all else. Jim
