Re: 656 farmall
Posted by Ted in NE on October 30, 2010 at 18:39:52 from (74.85.105.254):
In Reply to: Re: 656 farmall posted by willie mahr on October 29, 2010 at 18:30:31:
Did The line you replaced have a block that bolted to the front of the lift houseing?
If so did it have a small plug in the block? If I remember right there should be a spring loaded plastic check valve under the plug. Make sure it is in place. Could use the one out of the old line. Is the sump check for the power steering.
