Posted by John T on October 31, 2010 at 08:34:23 from (66.244.97.31):
In Reply to: Farmal B not firing posted by rronch on October 31, 2010 at 08:26:03:
My Troubleshooting procedure linked below can help diagnose the cause of no fire in a battery powered coil ignition system.
Its possible to get a 6 volt Alternator and even possible to get one Pos or Neg ground, but Id say the majority of alternator conversions are indeed 12 volt and most alllllllll use Neg ground.
Does it have a 6 or 12 volt battery in it ????? Is it configured Pos or neg ground???
If the tractor was originally Pos ground and it got switched to Neg ground, the coil wires need swapped and likewise the ammeter if it has one.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
