Re: need clutch and manual w/wiring diagram for Super C
Posted by Clint Proeschel on June 24, 2000 at 19:15:27 from (209.251.6.127):
In Reply to: need clutch and manual w/wiring diagram for Super C posted by Tom Stephenson on June 21, 2000 at 10:12:04:
I would trade you even up for my C which has a new clutch and a 12-volt system, if you deliver it to Ohio! My father split this tractor and put the new clutch in it. I reccommend using Case IH parts. While you have the tractor split, replace the starting ring gear that goes around the flywheel. especially if it looks worn.
Post A Followup
: Re: Re: need clutch and manual w/wiring diagram for Super C
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
