Posted by Janicholson on October 31, 2010 at 12:27:20 from (67.72.98.45):
In Reply to: 51' H - running rough posted by bmagee on October 31, 2010 at 11:48:06:
It probably has a stuck valve. Easiest check: Pull the plugs out and with a little help, (and in neutral) have someone crank the engine just a few turns with your thumb covering the spark plug holes, one at a time. If one hole has no or little pressure, It is probably that cylinder. Pull the valve cover off and you will probably find a valve that is open, with the pushrod laying disconnected. Spray a penetrating oil on the underside of the keeper where the valve stem enters the guide, then tap on the top of the valve with a plastic hammer. Peck at it, do not pound. It will probably begin moving, and spring back closed. Put the pushrod back on, and adjust the valves to .020 cold. Then put it back together temporarily and adjust the valves when warmed up to .017".
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
