Re: head bolt torque
Posted by rustred on November 01, 2010 at 20:04:28 from (74.198.148.46):
In Reply to: head bolt torque posted by bkpigs on November 01, 2010 at 19:11:21:
your in good shape, just retorque to 80 lbs and all is fine. the plenty copper coat thing is not nesessary , as it only takes a thin film on gasket as the rest will only be squeezed out anyway. its just a little extra insurance for no leaks. make sure you reset your valve lash as it will decrease once you torque head again.
Today's Featured Article - Talk of the Town: Can You Patch a Tire Sidewall? - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Has anyone attempted (or succesfully) glued or bolted a patch to the tires' sidewall. I cannot afford a tire right now but have some horse stall mat material and could buy some glue. I could use some advice on ... [Read Article]
