Re: farmall h hydraulic fluid
Posted by holmesw on November 02, 2010 at 07:08:47 from (99.196.160.57):
In Reply to: farmall h hydraulic fluid posted by porter ron on November 02, 2010 at 02:12:08:
Hy-tran will work fine, only expect that if your seals are not already bad, they will all be before too long. I have a super H, and when the hy-tran was put in it, all the seals blew out, because hydraulic oil is too thin. I would suggest using 30 weight non-detergent, as long as you do not hook your hydraulics up to a modern piece of machinery that is designed for regular hydraulic fluid. I have heard of some guys putting in 90 weight gear lube, and having good success with it. Only do not expect to be able to use it in cold weather, as it will probably be like molasses.
