Posted by RN on November 02, 2010 at 08:08:27 from (184.60.14.1):
In Reply to: Non-Running Farmall M posted by Erik MN on November 02, 2010 at 07:39:50:
scrap is $80/120 a ton in your area? You have 2 tons in M, offer accordingly. Problem is a "suspected head gasket" that"s been setting outside -or inside- 15 years is liable to have a siezed engine and needs complete rebuild. You might get lucky and only need oil change and put some ATF/Acetone in cylinders, charge battery to start-- but NOT likely. Running work Ms going from $1000.00 to $2000.00 - if you don"t want a rebuild project, don"t offer much more than scrap and part out the main pieces over 6 months. If you have some time and open shop space- rebuild kits are available with pistons, sleeves, gaskets for $500.00/$700.00, add cost of 10 gallons oil- the tranny and rear end hold a lot-check tires and have fun. A 40/50 hp newer tractor will set you back $20,000.00 plus. RN.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
