Posted by glennster on November 02, 2010 at 09:57:23 from (76.223.249.242):
In Reply to: Hard starting H posted by Josh V.L. on November 02, 2010 at 09:06:16:
before you throw any more parts at it, give it a good checking over first. pull a spark plug and see if you have a bright blue spark when you crank it over. check the ignition timing. check the fuel flow at the carburetor, pull the drain let it run in a can for a minute or so. clean and check the oil bath air cleaner. then run a compression test both dry and wet and see what kind of cylinder pressure you have. around 90 psi each cylinder is the minimum i'd be looking for, with no more than 10 percent variation between cylinders. with it having to get a sniff of ether to start, i am leaning to low compression, either rings or valves. run compression with ignition off, throttle wide open, all spark plugs removed. then go back with a couple oil can pumps of oil in each cylinder and re-run the test.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
