Re: f-12 magneto
Posted by TMAC on June 25, 2000 at 07:10:28 from (207.144.168.15):
In Reply to: f-12 magneto posted by Carl Holoway on June 22, 2000 at 16:37:12:
As you crank the engine, listen for the 'click' sound from the mag. If you don't heard it, the impulse coupling is stuck and it won't spark. I have tapped the mag at coupling and freed the impulse and it worked. If this is your problem then you need to use a light oil for the lube points.
Post A Followup
: Re: Re: f-12 magneto
