Re: 460 Questions and thanks!
Posted by bc on November 02, 2010 at 16:57:36 from (69.151.29.110):
In Reply to: 460 Questions and thanks! posted by Bud DeLong on November 02, 2010 at 07:39:45:
Bud, the easiest thing to do is pull the oil level plug on the side and fill it. Then make you a dip stick with a tape measure, dowel rod, stick or whatever. Run it all the way to the bottom of the tranny. Mark the oil level. You never have to pull the side plug again. If you have drained it or it is low, you can add a quart/gallon at a time and make a mark. Besides the seal the tranny has a habit of leaking and allowing the hydraulic pump to suck air. The cure is to overfill it by 5 gallons. Doesn't hurt to overfill it by that much. Done all the time by people here.
