Re: fuel line on a C
Posted by Ron-MO on November 02, 2010 at 19:11:17 from (174.131.231.125):
In Reply to: fuel line on a C posted by Dave Cook on November 02, 2010 at 15:38:39:
I guess I will toss my 2 cents in, but I have not tried putting a filter on my tractors. My C has what I believe to be the original sediment bowl. Or at least this is the same one that has been on it for nearly 50 years as it has not been replaced in that length of time. I have replaced the screen, gasket on the bowl, screen in the inlet of carb, and I had to replace the steel line due to the brass fittings being rounded off from being removed to service carb. I took the line down to auto parts store and found a near identical length of straight brake line, which I bent to match. Mine did not have a loop, and i believe that to be the original line that I replaced. First line lasted about 50 years, and this replacement has went about 10 so far without cracking. I am reluctant to replace the sediment bowl with an aftermarket, as I do not believe the replacements will hold up for more than a few years at best.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
