Re: head bolt torque
Posted by Stuart on November 02, 2010 at 22:12:57 from (64.198.86.189):
In Reply to: Re: head bolt torque posted by old on November 02, 2010 at 22:01:02:
That is because you have an IT manual not an IH manual. You see I have a dyno and if you torque on the head bolts is to low and you put the engine to work, it will leak. You try to help people with incorrect info.
Today's Featured Article - Talk of the Town: Can You Patch a Tire Sidewall? - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Has anyone attempted (or succesfully) glued or bolted a patch to the tires' sidewall. I cannot afford a tire right now but have some horse stall mat material and could buy some glue. I could use some advice on ... [Read Article]
