Re: Is the 504 a good tractor?
Posted by karl f on November 03, 2010 at 09:20:03 from (209.188.106.159):
In Reply to: Re: Is the 504 a good tractor? posted by semper fi guy II on November 03, 2010 at 05:21:50:
504 shares the shift pattern and the fact that it has a TA available. Some had a shuttle type reverse instead--make sure you find out in low gear and not the hard way at speed! some didn't have anything but a clutch and the gear shift.
The hydraulics are most like those on current production tractors vs. the MTA.
as for operating platform, it is "light years" ahead of an MTA. You mount from the side and sit in an office chair.
I would say its operator station is closer to the 8N you are accustomed to, with a more comfortable seat.
Diesel will meet or beat the economy of the 8n while doing bigger jobs.
You know what you like. mount the platform, see if you like the way the controls are laid out. Then take a test drive. Take it or leave it. If you still like the 8n more, look for a 2000 3000 or 4000 or even 5000 ford (late 60s-'75 production). The ford hundred series might also make you happy, they were made much earlier, and the 4 cylinder thousand series was made in between.
karl f
ps While I might agree that the MTA is over-rated in popularity, I would disagree about the over-rated-ness in mechanical and functional discussions.
