Re: Is the 504 a good tractor?
Posted by mkirsch on November 03, 2010 at 10:40:57 from (64.80.108.55):
In Reply to: Is the 504 a good tractor? posted by semper fi guy II on November 03, 2010 at 04:58:34:
Well then, a 504 is not for you. It is basically an MTA in miniature, with a much more complicated hydraulic system.
Whatever's wrong with your MTA, is probably due to age, wear and tear. If you want to avoid that, buy a NEW tractor. Otherwise, ANY tractor you buy will be a potential egg-sucker.
