Re: Farmall A Crack... Weld/New/ or JB?
Posted by Red Dave on November 03, 2010 at 12:08:37 from (66.216.141.163):
In Reply to: Farmall A Crack... Weld/New/ or JB? posted by Tomrentsc on November 03, 2010 at 11:59:18:
If the crack is on the side of the block, behind the carburator, and the block is OK otherwise, I would JB Weld it and grind it smooth. There are a lot of tractors out there with that crack.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
