Re: Farmall A Crack... Weld/New/ or JB?
Posted by old on November 03, 2010 at 13:50:30 from (4.245.14.239):
In Reply to: Farmall A Crack... Weld/New/ or JB? posted by Tomrentsc on November 03, 2010 at 11:59:18:
Depends on how bad the crack is. I have a block from a B that is so bad that I would not trust it. Or should I say I parted the tractor out because of it and now that I have opened up the engine I am happy I did it that way because it was cracked so bad that the JB weld that was on it only hide the real problem and the crack is so bad it would not have lasted very long it used much if any
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
