If the crack isnt realy bad so the block is cracked between the cycls there are different stuff that will last forevr. I have one that they welded and realy made a mess. I ground it down got rid of the mess and then used ruvver cement that they use when installing a new windshield. Let it set in the sun so it got nice and warm then spread the stuff on. That was 10 yrs ago and has been on several rides and other uses no sign of any leak.If tou will rough it some after appling to look like cast it should last forever and you cant even tell its been fixed. The JB will want to run when setting up but you could use a couple of treatments. I have also patched with fiberglass and that works also. Have the one i mow with thats been that way for many yrs and will hold up.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
