From my own experience in getting some tough ones free, a quarter inch hole drilled through the center section right at the point where the end of the knee tube rides inside the center tube allows penetrating oil to get just where it is needed most. The axle knee tube is " belled" on the end and there is little clearance between the outside diameter of the knee tube and the inside diameter of the center tube. Drill the hole just through the top side of the center tube, put in some oil and heat it good all the way around the center tube where the end of the knee tube will be on the inside of the center tube. The rustiest place will be on the bottom insides of the tubes due to water going in the adjustment spacing holes of the knee tubes. Once you get the knees out, clean and sand inside of center tube and outside of knee tubes . Spot of welding to close the small drilled hole, grind it smooth, paint where needed and lube things good before putting back together.
I remembered seeing this discussed on Red Power a few years ago. Here is address to site. They had some good ideas .
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
