Re: Farmall .H, 6 volt starter
Posted by Faster346 on November 03, 2010 at 19:48:15 from (72.241.213.69):
In Reply to: Farmall .H, 6 volt starter posted by stevecl on November 03, 2010 at 19:24:26:
How old are your cables? How are your grounds? If your cables are old they might need replacing. Even if they appear OK they are probably old and brittle inside. Also be sure to be using 0 Gauge, or 1 Gauge power and ground wires. Also be sure your grounds are shiny and clean. My M used to turn over real slow until I pulled the cables and cleaned all the connection points. Now it wings over about as fast as my 12v M does.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
