Re: Farmall H Hydraulics
Posted by wayne in mn on November 03, 2010 at 19:58:20 from (24.179.165.114):
In Reply to: Re: Farmall H Hydraulics posted by wdr84 on November 03, 2010 at 19:09:58:
Is there oil in the pump? Is the drive coupling in place? You need both of these before anything will happen.
Drive coupling is about 4" long and 1 3/4" diameter. Look under the center of the tractor at the rear of the pump for the coupler.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
