I'd remove the "dust pan" cover under the clutch housing, just to the rear of the belly pump, and verify the short coupling shaft is installed that connects the belly pump to the trans. If the tractor is running and the clutch pedal is not pushed down, that coupling shaft should be spinning and driving the belly pump. If the coupling shaft has been removed, the pump gears won't be turning and nothing will happen when you pull on the lift lever.
If the coupling shaft is installed, the pump's drive shaft is turning, and you have around 6 quarts of oil or hydraulic fluid in the pump reservoir, the pump will be circulating the fluid from the reservoir, through the pump, and down the bypass opening back into the reservoir.
When you pull the lift lever all the way up, the bypass opening inside the pump should close, and hydraulic pressure should build. I would think you'd be able to hear or feel something as that happens.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea
... [Read Article]
Latest Ad:
[More Ads]
