Re: Widening Trouble/front axle on 1066 or 1466 or ?
Posted by soybeanjoe on November 03, 2010 at 21:34:46 from (66.213.171.108):
In Reply to: Widening Trouble/front axle on 1066 or 1466 or ? posted by BigRedEd on November 03, 2010 at 13:59:36:
We'vemovedsome stubborn front axles before. Once did it as another poster said by chaining a tractor to each side except we put a chain hoist in bewteen the axle & one tractor to pull on the axle. Still had to heat & bang it with a large sledge.
Last one I moved was on a 806 that had been used as a loader tractor. One that one I used a rosebud torch, BFH, & a porta power. I put the porta power between the cast mounting bracket on the tractor & the other end against the outer arm. If I ever do anither one I'll use the porta power again. I had worked on it for several hour, even tried dumping the front wheel against a large rock to break it free. Once I used the porta power it moved right away. A lot easier than any other way I had done before.
