Re: Farmall B on side of the road...
Posted by Dave H (MI) on November 04, 2010 at 07:02:20 from (205.188.116.73):
In Reply to: Farmall B on side of the road... posted by dstates on November 03, 2010 at 19:28:23:
Looks pretty good to me. I would sell that seat and scare up an original. Needs a battery box and a battery that fits in it. Sheet metal, fenders, nose seem pretty good. Has pulley, drawbar, looks like it could be original electrically but won't swear by it. At least I don't see an alternator and spaghetti wires running all over it. I would run it around a fair amount in all gears and mebbe try seeing if it will pull something on wheels that is fairly heavy. If it seems mechanically sound I would buy it for anything in the low $1000 range. My initial budget would be $3-500 for parts, gaskets, seals, kits etc. I hate dripping tractors. If you are going to paint, double that estimate and add a little more. Tires you can shop but $300 each for new rears is not out of the question. I would consider that a promising prospect. You should see some of the stuff I drag home.
