Re: 666 remote valve spool removal
Posted by pete 23 on November 04, 2010 at 07:35:01 from (184.12.34.48):
In Reply to: 666 remote valve spool removal posted by WOK on November 03, 2010 at 19:59:53:
I would caution you on tightening the cap as one of our customers did that and broke the valve. My BIL was a good welder and he was able to weld it and it worked out fine but was more luck than sense. What I do to loosen the sleeve is use a sharp chisel and carefully try to coax it with a few light taps in the correct direction. If you nick that outside no problem. Some are steel and some are pot metal but either way it does the job usually.
