Re: Removeing fan from fanshaft on 48 H
Posted by Crazy Red Power in SE-WI on November 04, 2010 at 08:39:03 from (24.183.132.223):
In Reply to: Removeing fan from fanshaft on 48 H posted by Farmallb on November 04, 2010 at 08:24:01:
I've had the best luck getting that pin out by loosening the retaining nut half-way & tapping on the nut 'till the pin starts to work out the other side. Take the nut off after that & tap the drive pin through. If it's rusted tight, hit it with your best penetrating oil, let it sit for a minute or two & then perform the process above. Keep your hand in front of the part that retains the springs. Every once & a while you find a loose one that will take off, fron the studs, with the springs closely behind. Not that I'd know, or anything. Then, I think, you pull the two studs & four bolts & you should have a free fan. I'm only running on memory, here, as I can't find the durned service manual. Dats what I get for cleaning!
Mike
Today's Featured Article - A Lifetime of Farm Machinery - by Joe Michaels. I am a mechanical engineer by profession, specializing in powerplant work. I worked as a machinist and engine erector, with time spent overseas. I have always had a love for machinery, and an appreciation for farming and farm machinery. I was born and raised in Brooklyn, New York. Not a place one would associate with farms or farm machinery. I credit my parents for instilling a lot of good values, a respect for learning, a knowledge of various skills and a little knowledge of farming in me, amo ... [Read Article]
