Re: H carb wont stop leaking
Posted by mkirsch on November 04, 2010 at 10:51:56 from (64.80.108.55):
In Reply to: H carb wont stop leaking posted by chevy_cowboy on November 04, 2010 at 09:33:18:
The needle isn't closing, period.
Most likely cause is the float is hanging up on the side of the bowl.
There isn't a whole lot of wiggle room for the float inside the carb. If that float gets tweaked even just a little, it will hang up on something.
Worst part of it is, you can't tell if the float is going to hang up or not because you can't see inside the carb when it's assembled.
I had a problem where the float would hang up and hold the needle CLOSED. Took it apart 4 times before I got it straightened out.
