Posted by M Diesel on November 04, 2010 at 11:14:53 from (12.24.61.12):
In Reply to: 650 IH posted by plow hand on November 03, 2010 at 19:44:15:
I'll add in that the butterflies in the intake manifold are a major culprit for not starting on gas. Their job is to divert air from the main passages into the carb passages. They are not forced closed. The linkage just pushes the shaft past center and then a spring on the shaft (in the end of the manifold) pulls an arm over center and finishes the job. If the shaft develops a bit of a drag it won't snap closed. You can reach in behind the manifold and work the shaft manually to a certain degree. The feel will tell you if it isn't right.
Another FYI, the butterfly shaft kills the ignition when in diesel. There is a switch at the front end, presuming it is hooked up.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
