Re: Farmall H Hydraulics
Posted by WDR84 on November 04, 2010 at 12:33:17 from (69.207.66.84):
In Reply to: Farmall H Hydraulics posted by WDR84 on November 03, 2010 at 17:48:10:
Hey Guys thanks for the help. I have determined the problem, however, still need some help. I removed the belly inspection cover and everything looked ok. When i removed the drive coupler (shaft with two collars and cotter pins) i found that the coupler that threads onto the pump drive shaft would spin without spinning the shaft...not good! I removed the pump and pulled the pump,tore it apart, and removed the drive shaft. It was definitely stripped bad. The coupler still looks like it has good threads, however, the drive shaft is smooth as can be. Any ideas as to where i can get a new drive shaft? Also, any ideas as to why this would have happened? Thanks again for all the help(except for gene bender).
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
